Obecny czas: 12 Sty 2026, 11:48
 Post #759365 Wysłany: 18 Sty 2015, 17:48;
 Temat postu: Fiat punto steering wheel radio controls
Imię: Gediminas
Miejscowość: Lithuania
Hello, I have Punto II FL with steering wheel radio controls, but all buttons only can mute sound. Also Multiecuscan in can info doesn't show steering wheel control node. any help?
Image Image
 Post #759367 Wysłany: 18 Sty 2015, 18:14;
 Temat postu: Re: Fiat punto steering wheel radio controls
Hi.
Is the radio installed by factory (Blaupunkt) or it was bought later? Is the LCD (below speedometer) blinking? Did you check the wires behind radio and in the wheel radio controls? Maybe something's broken there?
Koledzy ze sterowaniem radia w kierownicy (to owners in Poland): rzućcie okiem, czy w FES/MES mając sterowanie radia w kierownicy widnieje ten moduł jako aktywny lub zainstalowany.
 Post #759368 Wysłany: 18 Sty 2015, 18:35;
Imię: Gediminas
Hi domin45670,
I am talking about JTD HGT, so it has all wiring and factory fitted steering wheel with controls. Radio was removed when I buyed car, installed punto high mp3 radio and it works. LCD doesn't blink. Wires are not broken behind radio.
Image Image
 Post #759371 Wysłany: 18 Sty 2015, 18:46;
Do you still have this radio? If you have it, try swap it to the old one and than check the wheel radio controls. This test will tell us where we should seek your problem (in radio or somewhere else).
 Post #759374 Wysłany: 18 Sty 2015, 18:52;
Imię: Gediminas
No, radio was removed by previous owner in Italy.
Image Image
 Post #759383 Wysłany: 18 Sty 2015, 22:18;
Ok, so...
Use multimeter to check wheel radio controls (open it) and wires behind them and wheel drive. Before you check wires behind steering wheel, remove battery, wait few minutes and than remove airbag.
If it's possible ask people in Lithuania about rent other radio for a while, to check the controls.
Anyway, maybe someone else will have any idea in your problem. We should wait :mysli:
Let us know if you find more clues.
 Post #760216 Wysłany: 24 Sty 2015, 17:16;
Imię: Gediminas
Found some info in this forum: post667881.html tomorrow will try to add new wire because I think somethere it is faulty.
[ Dodano: 24 Jan 2015 18:16 ]
Finally all buttons working, connected new 3 wires.
Image Image
